IE on Vista not working with ACE
Aug 27th, 2008
  • Bronze, 100 points or more
IE on Vista does not work hitting ACE (ACE10-6500-K9 / c6ace-t1k9-mz.A2_1_1.bin) but
If we use the following browser (IE on XP, safari, Mozilla on XP or Vista), it works but if we use IE on Vista, we cannot access our website.
sbilgi Tue, 09/02/2008 - 11:23
  • Silver, 250 points or more
It will not support (IE)on Vista with ACE.
aamercado Tue, 09/02/2008 - 22:12
Actually, IE on Vista is supported...well, at least version 7. The problem was that On IE7, it is TLS which seems to be turned on by default on 7 but off on 6.
Also, I had the following and removed "ssl advanced-options sslparams" and it worked.
parameter-map type ssl sslparams
version SSL3
ssl-proxy service sslproxy
