Advices about use of fwsm, spa vpn ipsec & cca mode
Aug 27th, 2008
I didn't found a lot of information, documentation of knowledge about integration of fwsm, spa vpn ipsec with cca mode.
Fswm will be directly connected with a public addres and translate to a private address with a nat.
My VPN ipsec will be terminated after the FWSM.
I need to use global VRF and Ivrf (why I need to use CCA mode)
Differents clients to differents vrf
Configuration like this
Vlan 10 -- FSWM context --vlan 11 outside ipsec - SPA card - vlan 100/VRF customer1 --
- Vlan 200/VRF Customer2 --
ip vrf customer1
rd 100:1
ip vrf customer2
rd 200:2
crypto isakmp policy 10
encr 3des
hash sha
authentication pre-share
crypto keyring customer1-key
pre-shared-key address 2.0.0.1 key 12345
crypto keyring customer2-key
pre-shared-key address 2.0.0.2 key 12345
crypto ipsec transform-set strong esp-aes 256 esp-sha-hmac
crypto engine mode vrf
Crypto isakmp profile customer1
vrf customer1
match identity address 2.0.0.1/32
Crypto isakmp profile customer2
vrf customer2
match identity address 2.0.0.2/32
crypto map cm local-address vlan 11
crypto map cm1 10 ipsec-isakmp
set peer 2.0.0.1
set transform-set strong
set isakmp-profile customer1
match address acl customer1
crypto map cm2 20 ipsec-isakmp
set peer 2.0.0.2
set isakmp-profile customer2
match address acl customer2
interface vlan 100
ip vrf forwarding customer1
ip address 10.1.1.1/24
crypto engine subslot 1/0 inside
crypto map cm1
interface vlan 200
ip vrf forwarding customer2
ip address 10.2.2.1/24
crypto map cm2
interface vlan11
ip address 10.0.0.2/30
crypto engine subslot 1/0 outside
