08-28-2008 12:49 AM
Hi everybody,
I have a 3725 with NM-30DM and I'd like to replace it with a 2811 with PDVM2-36DM.
Here you find the 3725 configuration and the new configuration I put in 2811:
3725:
card type e1 2
modem country mica italy
virtual-profile virtual-template 1
isdn switch-type primary-net5
controller E1 2/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 172.17.9.3 255.255.255.240
speed 100
full-duplex
interface Serial2/0:15
no ip address
encapsulation ppp
dialer idle-timeout 600
dialer load-threshold 5 outbound
isdn incoming-voice modem
ppp authentication chap
ppp multilink
ppp multilink load-threshold 5 outbound
interface Virtual-Template1
ip unnumbered FastEthernet0/0
peer default ip address pool dialup
ppp multilink
interface Group-Async0
description Interface Async Dial-In
encapsulation ppp
ip tcp header-compression
dialer in-band
async mode dedicated
ppp authentication pap chap
ppp multilink
group-range 33 62
ip local pool dialup 172.17.9.129 172.17.9.254
dial-peer cor custom
line 33 62
session-timeout 600
script reset cisco
modem Dialin
modem autoconfigure discovery
autocommand ppp
transport preferred none
transport input all
transport output none
autoselect during-login
autoselect ppp
2811:
card type e1 1
modem firmware slot 0 location flash:V3_07.axf
modem country v12 e1-default
controller E1 1/0
ip address 172.17.9.4 255.255.255.240
duplex full
speed 100
interface Serial1/0:15
description *** ISDN PRI BT Italia ***
no ip address
encapsulation ppp
ppp multilink
ppp multilink
encapsulation ppp
dialer in-band
ppp multilink
group-range 0/322 0/357
line 0/322 0/357
session-timeout 600
modem InOut
autocommand ppp
transport input all
autoselect ppp
With this configuration the 2811 is unable to receive incoming calls. I tried also to use 'modem country v12 italy' but it didn't work.
What's wrong with the new configuration?
Many thanks
Stefano
Solved! Go to Solution.
08-28-2008 04:04 PM
Please try adding the network-clock participate and select command as appropriate for your setup:
Example - NOTE: you will need to add E1 instead of T1
network-clock-participate slot 1
network-clock-select 1 T1 1/0
network-clock-select 2 T1 1/1
Thanks, Mak
08-28-2008 04:04 PM
Thanks, Mak
08-29-2008 12:16 AM
It works!!
Thank you so much!
Stefano
