Default Interface Config
Answered Question
Aug 28th, 2008
Is there a way of changing the config of an interface or range of interfaces back to there default configuration without having to work through all the commands and negateing them?
The switches we use are 2950, 2960, 2970, 3750 and 6500.
Correct Answer by Giuseppe Larosa about 8 years 8 months ago
Hello Jon,
you can use
default interface type x/y
default interface range ....
from global config
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Thu, 08/28/2008 - 01:05
  • Hall of Fame,
    Founding Member
Hello Jon,
you can use
from global config
Hope to help
Giuseppe
