How to block users to dialout in Call Manager 6.x after working hours
Answered Question
Aug 28th, 2008
How to block users to dialout in Call Manager 6.x after working hours ?
Correct Answer by Ayodeji oladipo... about 8 years 1 month ago
you can use Time of Day routing to achive this.
Bear in mind that you will have to assign the Route patters you want to restrict to the time period partition you have created for ToD routing.
Here is an excellent tutorial on how to configure this..
Overall Rating: 5 (2 ratings)
Marwan ALshawi Thu, 08/28/2008 - 01:14
Time of Day Routing
The ability to route calls based on time of day is a feature that is available in CallManager 4.1 and later. This added function allows certain calls to be allowed and restricted based on time of day. It works in concert with CSS and partitions, which allows you to apply certain time-of-day routing rules to one group of users and other rules to other groups.
In the simplest terms, the way this works is that a time frame is assigned to a partition. During that time frame, the partition is accessible by any device that has a CSS that includes the partition. Outside that time frame, no device has access to the partition.
for example
if u creat a partition called P1
and assigned this partition ti ur outside route-pattren
and this partion will be included in ur users CSS to have access to this outside pattren
make a time period for working hours
then creat time sechedule include ur working hours time period
Assign a Time Schedule to the Partition
like the P1 u have it
in this case
this partion will be working upon the time u put it out of that time will be deactivated then not dialout
good luck
please, if helpful Rate
