IPS unable to Block
Aug 28th, 2008
I have IPS 4255, I have made a Service HTTP signature to block metacafe.
I have configured the block device for PIX Firewall. Signature triggers when i open www.metacafe.com i can see the user IP in active blocking hosts and also in IP logging but still i m not able to block/shun the users.
I select all actions in signature definiation.
-----Network Access Statistics-----
section Current Configuration
LogAllBlockEventsAndSensors true
EnableNvramWrite false
EnableAclLogging false
AllowSensorBlock false
BlockMaxEntries 250
MaxDeviceInterfaces 250
section NetDevice
Type PIX
IP 172.28.31.68
NATAddr 0.0.0.0
Communications ssh-3des
ResponseCapabilities block
section NeverBlock
IP 172.28.92.72
IP 172.28.31.0
IP 192.168.249.0
IP 192.168.250.0
section State
BlockEnable true
section NetDevice
IP 172.28.31.68
AclSupport Does not use ACLs
Version 0
State Inactive
Firewall-type PIX
Please help me out what i m missing.
Farrukh Haroon Thu, 08/28/2008 - 03:18
  • Red, 2250 points or more
Did you allow the sensor IP on the PIX for SSH?
ssh interface ?
Did you add the PIX as a trusted host on the sensor?
Is the SSH even working on the PIX from other hosts?
Double check your PIX credentials.
Login to PIX and issue a 'who' command to see if the IPS is logged in.
Farrukh
wasiimcisco Thu, 08/28/2008 - 06:32
Thanks for the reply,
My firewall is configured for AAA. I gave the same credential in IPS blocking devices that i m using for myself.
SSH is allowed on firewall for any IP.
IPS also has any ip to trusted hosts.
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
IPS allowed host
telnet-option enabled
access-list 172.28.0.0/16
IPs only able to push access-list on router but not able to shun pix firewall.
wasiimcisco Thu, 08/28/2008 - 09:00
I have tried even this, but still the problem is there,
I am attaching the screen shot, I am not able to configure block action, the tab is not highlighted.
why it is so, may be this is the reason.?????
Farrukh Haroon Thu, 08/28/2008 - 10:44
Have you enabled blocking globally?
Blocking >> Blocking Properties
Farrukh
wasiimcisco Thu, 08/28/2008 - 13:03
yes blocking is globally enabled. IPs able to write access-list on routers but not able to shun pix firewall.
Farrukh Haroon Fri, 08/29/2008 - 10:54
Please enable the block action on any common signature like ICMP echo (2004) and then check the event log of the IPS. It will tell you why the shun is failing. Also login to the firewall and do a 'who' command during this test to see if the IPS logs in. Do 'terminal monitor' and 'logging monitor 6' on firewall to see any denies etc.
Farrukh
wasiimcisco Thu, 09/04/2008 - 03:22
I am not able to configure firewall shun in cisco IPS, The option of blocking is disable in IPS for Firewall.
See the attachement. Please help me out how to do this.
IPS is only able to block the routers but not firewall
wasiimcisco Thu, 09/04/2008 - 03:44
When i view the log on IPS, it shows me the following error
firewall type unknow. Please see the screen shot.
Secondly when i did who on firewall i didnt see anybody connected. Firewall logging is also not showing that IPS IP address is block.
