ASA failover when IPS SSM fails
Is there a way to trigger stateful (or stateless) failover on ASA 55xx (8.0.3) when there's a failure on the IPS unit? I understand the fail open/fail close and its application on a single firewall, but the better solution for an IPS failure in a redundant pair would seem to be a stateful failover to the other ASA, and I don't see that as a documented feature.
Overall Rating: 5 (2 ratings)
satish_zanjurne Thu, 08/28/2008 - 05:47
ASA has only following Failover Triggers , IPS failover trigger is not present..
The ASA unit can fail if one of the following events occurs:
• The unit has a hardware failure or a power failure.
• The unit has a software failure.
• Too many monitored interfaces fail.
Jmayes, what you are saying is good feature..but i think it is not incorporated yet..!!!!
robertson.michael Thu, 08/28/2008 - 07:56
Hi Joseph,
If the SSM in the Active unit fails (i.e. 'show module' shows the SSM as "Down"), a failover will occur and the Standby unit will now become Active. The ASA does interpret a failed SSM as being less healthy than its mate who has an available SSM.
Hope that helps.
-Mike
robertson.michael Thu, 08/28/2008 - 09:03
Hi Joseph,
Oddly enough, I wasn't able to find this mentioned in the ASA documentation. However, from experience I can tell you that a failed SSM will cause the unit to mark itself as unhealthy.
-Mike
satish_zanjurne Thu, 08/28/2008 - 10:30
Hi Robertson, if it is working..then it must be..but i have not seen it documentted
dazza_johnson Tue, 05/03/2011 - 19:07
Excellent post, I'm surprised this isnt documented better. To test this I did the following;
Command on the Active ASA to shutdown the IPS module;
hw-module module 1 shutdown
this forces a failover to the Standby ASA. To restart the IPS module again, enter;
hw-module module 1 reset
Good work guys :-)
Dazzler
