TCL Script to shut down power to IP Phones
Aug 28th, 2008
  • Silver, 250 points or more
I've already posted this in the Unified Comms section but had no response so thought I'd try here.
Does anyone know of a way to shut down the power to IP Phones lets say every evening and weekends to conserve power? Just thinking green!!
Would a TCL script do the job or are Cisco looking into ways of doing this in the future?
TIA.
Overall Rating: 3 (3 ratings)
Darren,
Not sure about TCL - but I have a telnet script program that telnet's to a cisco switch that provides PoE.
I have it logon at 7pm on Friday and issue the below commands:-
interface range g1/0/1 1/0/48
power inline never
this shuts power off to all the switch ports that have phones attached.
Then Monday morning a 7am another script is run:-
no power inline never
Works for me!
HTH>
dezoconnor Thu, 08/28/2008 - 05:20
Thanks to you both Mark & Andrew. I've now got something to go away and work with. Much appreciated.
spollock Sat, 10/16/2010 - 18:36
Looking for something simple for my UC500 @home.  Currently running 12.4(12.12)T
I would like to have a script run at night and turn all PoE ports off, then kick them back on early in the AM.  I had a look at the green script from the 6500 team at http://forums.cisco.com/eforum/servlet/EEM?page=search_results&fn=search&catId=1&count=20&skip=0&sortBy=3&order=DESC&mode=browse
This obviously won't work on the UC500 although the command
Cowacella#show power inline
PowerSupply   SlotNum.   Maximum   Allocated       Status
INT-PS           0        80.000    18.900          PS GOOD
Interface   Config   Device    Powered    PowerAllocated
Fa0/1/0     auto     Cisco    On         6.300 Watts
Fa0/1/1     auto     Cisco    On         6.300 Watts
Fa0/1/2     auto     Unknown  Off        0.000 Watts
Fa0/1/3     auto     Unknown  Off        0.000 Watts
Fa0/1/4     auto     Unknown  Off        0.000 Watts
Fa0/1/5     auto     Unknown  Off        0.000 Watts
Fa0/1/6     auto     Unknown  Off        0.000 Watts
Fa0/1/7     auto     Cisco    On         6.300 Watts
Cowacella#
gives a clue.
Rather than write one myself, which I will do if no one responds, I was hoping someone had already done this or found a better way.  There is nothing in the CCA menus about this (hint hint)
I also don't find EEM on here.  Seems to have come out in a later rev of ios.
