08-28-2008 04:31 AM - edited 03-15-2019 12:53 PM
We are trying to upgrade from 5.1.2.2000 to
5.1.3.1000-12 so that the system can support 7965 and 7975 .error was encounter during the upgrade.Any infos would be greatly appreciated. below are partial log from the upgrade
08/28/2008 19:25:39 AppInstall|End cmdExec: Command: /common/download/5.1.3.1000-12//base_scripts/xml_writer.sh
/var/log/install/upgrade-results.xml upgrade-result description Upgrade of platform files failed -- succeeded|<LVL::Debug>
08/28/2008 19:25:39 AppInstall|Internal Error, File:instUtil.c:691, Function: logXmlError(), Invocation upgrade_os.sh
failed|<LVL::Critical>
08/28/2008 19:25:39 upgrade_install.sh|Cleaning up download...|<LVL::Info>
08/28/2008 19:25:39 upgrade_install.sh|Removing /common/download/cisco-ipt-k9-patch5.1.3.1000-12.*|<LVL::Info>
08/28/2008 19:25:41 upgrade_install.sh|Removing /common/download/5.1.3.1000-12|<LVL::Info>
08/28/2008 19:25:46 upgrade_install.sh|Cleaning up misc...|<LVL::Info>
08/28/2008 19:26:03 upgrade_install.sh|Dumping /usr disk usage to /usr/local/platform/conf/usr_du_out.txt|<LVL::Info>
08/28/2008 19:26:03 upgrade_install.sh|Cleaning up rpm_archive...|<LVL::Info>
09-03-2008 08:30 AM
could be this bug:
CSCsi10459
sd_ntp -add -s issue during L2 upgrade
java
if this helps, please rate
09-30-2008 12:20 PM
thks.resolve by cisco tac
