ISDN PRI
hadisharifi
I have the following setup, both routers are Cisco 2811, I am trying to simulate PSTN on one routerB running CME and routerA is an MGCP GW controller by CUCM5. When placing a call from RouterA to RouterB the call goes through fine but when a call is placed from Router B to routerA the call doesn't go through, basically as soon as I dial the number the phone hangs up. I have done debug isdn q931 and getting the disconnect message not sure why.
RouterA ===== Fractional PRI ====RouterB "PSTN SIMULATOR"
*Aug 28 12:46:41.830: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 14085556666
*Aug 28 12:46:41.834: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 4085551001
*Aug 28 12:46:41.834: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0094
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '14085556666'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '4085551001'
*Aug 28 12:46:41.854: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8094
Cause i = 0x8080 - Unknown cause value
8 Replies 8
Ayodeji Okanlawon
Can you post a copy of the configs of both sides of the routers here
Please rate all useful posts
I have attached the configs for both routers.
Thanks for your help.
Ayodeji Okanlawon
In your config, there is no dial-peer for the called number 4085551001
What you have is this..
dial-peer voice 140855510 pots
description To SJC
destination-pattern 14085551...
incoming called-number .
direct-inward-dial
port 0/1/0:15
forward-digits 10
You are dialing 408555.... but you have 1408 in your dial-peer
If you intedn using your Voice xlation rule to strip the 1 then it is notproperly configured.
You have applied the direction as incoming while this is an outgoing call.
why dont you just use somehting like rule 2 /^1/ // and then apply the rule in the outgoing direction
Please ignore the translation and I have removed it, the correct digits forwarded is taken care of by the forward-digits 10 which I have changed it to 11 to send the full number 140855501001. But the call still doesn't go through.
I don't remember what it is but there is something specific when the phone hangs up the call as soon as a number is dialed.
Sorry, I missed the forward-digits 10.
Ok so the called number is now 140855501001.
On your MGCP gateway in CCM, how many digits do you have as your significant digits. And what is the extension number of the Phone you are calling.
Also Do you have any CSS on the gateway and does this CSS have access to the PT of the IP phone
Hi aokanlawon,
Thanks for your help, It's all good now.
The first issue was with the Gateway downloading it's config form the CCM and it wasn't reflecting the PSTN end, and I have turned it off now.
The second issue was with the significant digits as you have mentioned above, for whatever reason I though I had set it to four but it was set to 0, my extension are four digits.
Cheers
Good to know, its been resolved.
Dont forget to rate the posts!
Thanks, rated your post.
