7900 series phone display
Aug 28th, 2008
Was in A Sears store and noticed on their phones that where "your current options" is displayed they had Sears Store displayed.
Can someone tell me where that is configured.
Thank you
Rob Huffman Thu, 08/28/2008 - 05:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Stanley,
This is available in CME only, not CCM at this point in time;
Have you looked into using this CME Feature?
System Message Display
The System Message Display feature allows you to specify a custom text or display message to appear in the lower part of the display window on display-capable IP phones. If you do not set a custom text or display message, the default message "Cisco Unified CME" is displayed.
When you specify a text message, the number of characters that can be displayed is not fixed because IP phones typically use a proportional (as opposed to fixed-width) font. There is room for approximately 30 alphanumeric characters.
The display message is refreshed with a new message after one of the following events occurs:
Busy phone goes back on-hook.
Idle phone receives a keepalive message.
Phone is restarted.
The file-display feature allows you to specify a file to display on display-capable IP phones when they are not in use. You can use this feature to provide the phone display with a system message that is refreshed at configurable intervals, similar to the way that the text message feature provides a message.
The difference between the two is that the system text message feature displays a single line of text at the bottom of the phone display, whereas the ***system display message feature can use the entire display area and contain graphic images.
SCCP: Modifying System Message Display
To modify the system message display on phone screen, perform the following steps.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. system message text-message
5. url idle url idle-timeout seconds
6. end
System File Display: Example
The following example specifies that a file called logo.htm should be displayed on IP phones when they are not in use:
telephony-service
url idle http://www.abcwrecking.com/public/logo.htm idle-timeout 35
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1032353
Hope this helps!
Rob
safety2008 Thu, 08/28/2008 - 05:16
Thank you Rob.
Much appreciated. we are a ccm, but thought it to be a nice custom touch for business.
Rob Huffman Thu, 08/28/2008 - 05:38
  • Hall of Fame,
    Founding Member
Hi Stanley,
You are most welcome! It was worth a try :)
Take care,
Rob
