Need help on Unity call flow.
Aug 28th, 2008
Dear Friends. I want to know the call flow in the unity server. I want to know call flow for direct call and forwarded call.
Jaime Valencia Thu, 08/28/2008 - 06:32
direct is when you call the pilot, FW when following a call forward option.
not sure if that's what you're looking for, if not, please elaborate
you can use the call viewer to see this
if this helps, please rate
esa786_2 Thu, 08/28/2008 - 08:13
Hi. Thank u for ur reply. I want to what happening when direct or forwarded call comes to unity.
Jaime Valencia Thu, 08/28/2008 - 08:18
ok, the use the port status monitor if you want to see what happens to a call
sonepar Thu, 08/28/2008 - 08:20
I believe Unity use Direct Call Routing Rule when you push the message button on your phone (when checking voicemails) and if Voicemail account exist in Unity, it iwll take u to ur mailbox, prompt for a password.
In Forwarding rule, you get the greeting of that particular user. Used when someone try to leave u a voice message.....
