ACE - Probe
Aug 28th, 2008
I am trying to determine the best way to monitor the health of my servers. I have multiple Web Server instances running on different ports on the same physical server. So I have configured 1 RSERVER. In my Server Farm configuration I specify the RSERVER then the port number for each Web Server instance.
How can I monitor each Instance individualy?
I dont want to take the entire RSERVER out of service if just one of the instances fail. I just want to take the one instance out of service if that one instance has failed.
probe http EP-57100
port 57100
interval 2
faildetect 2
passdetect interval 2
request method get url /index.html
expect status 200 200
probe http EP-57300
port 57300
interval 2
faildetect 2
rserver host EP1
ip address 10.10.10.10
inservice
serverfarm host EP
rserver EP1 57100
inservice
rserver EP1 57300
inservice
Thanks for the help!
ciscocsoc Thu, 08/28/2008 - 07:00
Hi Phil,
I'm not sure of the architecture you are proposing, but one solution to achieve your stated objective is to define multiple rservers - one for each port. A probe can then be assigned to each rserver rather than the serverfarm as a whole.
Another solution might be to create multiple serverfarms - one for each web server instance.
Cathy
phil.wightman Thu, 08/28/2008 - 07:01
Ahh, yes. Good idea. I didnt consider that. That will work for me. Thanks for the help!
Syed Iftekhar Ahmed Thu, 08/28/2008 - 08:54
You cannot create multiple rservers with same IP address. Similarly there is no way to define a port under rserver definition. You can define probes under rserver configuration but not ports.
Are the different instances (listening on diff ports) are serving the same application? If yes then you can try
serverfarm host EP
rserver EP1 57100
probe EP-57100
inservice
rserver EP1 57300
probe EP-57300
inservice
Syed Iftekhar Ahmed
phil.wightman Thu, 08/28/2008 - 09:52
Thanks Syed, good point.
Yes, I am hosting the same application across the different instances. I will try, as you have suggested, placing the probes on the Serverfarm instances instead of the RSERVERS themselves.
Thank you
