Undersize frames on 3550 - CSCec14238 ever fixed?
Aug 28th, 2008
We have a setup which has been seeing connectivity issues between two routers connected through a 3550 switch running 12.1(20)EA1. Periodically the OSPF neighbour relationship will drop and HSRP will become active on router2, (both issues) due to router2 not seeing packets from router 1.
(We also see other connectivity issue related to this end hosts talking to router2, but I am concentrating on these two devices to keep troubleshooting simpler)
The topology is as follows:
The CPU on both routers remains low at the time the issue occurs and no errors are seen from show interface on either of the routers or either of the switch ports at the time the packets are lost. The only errors which are seen are on the switch using:
Swich1#sh int fa0/23 count er
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
Fa0/23 0 0 0 0 358490
Port Single-Col Multi-Col Late-Col Excess-Col Carri-Sen Runts Giants
Fa0/23 0 0 0 0 0 0 0
BR-AV-SWT-1#sh controll ethe fa0/23 | inc too s
0 Too large frames 0 Invalid frames, too small
109092189 64 byte frames 73894559 Valid frames, too small
Bug ID CSCec14238, suggests that reported undersize frames may be a cosmetic issue, however that should be fixed in the code running on the switch. Also there seems to be nothing else which would cause the loss of connectivity between the two routers.
Are the undersize frames a red herring? If so it would be nice to be able to get rid of them, if not where else should be looking?
Thanks in advance,
d-cardwell Thu, 08/28/2008 - 07:14
Hi Ajaz,
So the version 12.1(20)EA1 which is running should have the fix, meaning that these are NOT cosmetic errors?
Thanks for the quick reply
