Inboud calls to FXO
Aug 28th, 2008
I have CCME 4.0(3) on routeur 2801 and
I want to redirect the inbound calls from PSTN to four IP Phones. So when we call from the PSTN the 4 Ip Phones Ring.
I know that it is possible with connection PLAR on voice port but it support only one ephone-dn
Thankyou for your help
Malek
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 08/28/2008 - 07:15
Hunt Groups
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1118926
Hunt groups allow incoming calls to a specific number (pilot number) to be directed to a defined group of extension numbers.
Incoming calls are redirected from the pilot number to the first extension number as defined by the configuration. If the first number is busy or does not answer, the call is redirected to the next phone in the list. A call continues to be redirected on busy or no answer from number to number in the list until it is answered or until the call reaches the number that is defined as the final number.
java
if this helps, please rate
dbenattou Thu, 08/28/2008 - 07:17
hello,
you can do so by configuring the hunt group and the time between each phone must be very low.
Driss
microtel Thu, 08/28/2008 - 08:17
Thanks evrybody for your help.
CCME 4.0 can not support parralel ring, but it support sequentiel and i tune timout to 15s
Jaime Valencia Thu, 08/28/2008 - 08:19
in case you're interested CME 4.3/7.0 does support it now
java
microtel Thu, 08/28/2008 - 08:32
Please can u tell me witch IOS version embeed CCME 4.3 for 2801, I am looking for this version with software advisor but the recent one is 4.0.3
