VPN to Sonicwall
Aug 28th, 2008
Hi all,
I have an ASA 5505 and I'm trying to build a site to site VPN to a sonicwall firewall.
The firewall is doing NAT and has a net connection. I followed the directions at cisco's site to the letter (they had a document describing how to setup a VPN from a sonicwall to an ASA).
Anyway,
My LAN is 192.168.12.0/24 and the remote LAN is 10.5.0.0/24
Here's my config. Any ideas? I'm stumped.
ASA Version 7.0(7)
hostname asa1
domain-name test.net
enable password **************
names
dns-guard
interface GigabitEthernet0/0
nameif inside
security-level 100
ip address 192.168.12.14 255.255.255.0
interface GigabitEthernet0/1
nameif outside
security-level 0
ip address 66.*.*.2 255.255.255.252
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
passwd **************
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip any 192.168.12.0 255.255.255
.0
access-list pixtosw extended permit ip 192.168.12.0 255.255.255.0 10.5.0.0 255.2
55.255.0
pager lines 24
logging console debugging
mtu outside 1500
mtu inside 1500
no failover
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list pixtosw
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 66.*.*.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set austinlab esp-3des esp-sha-hmac
crypto dynamic-map ciscopix 1 set transform-set austinlab
crypto map dynmaptosw 66 ipsec-isakmp dynamic ciscopix
crypto map dynmaptosw interface outside
isakmp identity address
isakmp enable outside
isakmp policy 13 authentication pre-share
isakmp policy 13 encryption 3des
isakmp policy 13 hash sha
isakmp policy 13 lifetime 28800
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group 10.5.0.0 type ipsec-l2l
tunnel-group 10.5.0.0 ipsec-attributes
pre-shared-key *
tunnel-group 192.168.12.0 type ipsec-l2l
tunnel-group 192.168.12.0 ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
Cryptochecksum:xxx
: end
t4tauseef33 Tue, 09/02/2008 - 07:30
pre-shared-key *
pre-shared-key *
The above one is wrong
tunnel-group 216.183.* type ipsec-l2l
tunnel-group 216.183.* ipsec-attributes
pre-shared-key *
