IOS Question
dphills18
Is there an Advance IOS 12.4 (Security or Enterprise, IP Services) that will run on a 2801 with 128MB memory (DRAM). Boss went cheap on me. :(
I mainly need VPN 3DES for GRE IPSEC Tunnel
Thanks in advance. Find it and I will rate you very good.
PS>
Prefer 12.4T
mohammedmahmoud
Level 11
Level 11
Kindly use Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
P.S I don't believe that you'll find a 12.4T that runs with 128MB DRAM on the 2801, but you'll find a 12.4 code.
BR,
Mohammed Mahmoud.
