ssl vpn 1.1.3 disconnecting, VPN Concentrator 3005
Aug 28th, 2008
I have a VPN Concentrator 3005 running vpn3005-4.7.2.L-k9.bin and I am using the SSL client for webvpn 1.1.3. I am having users complain that when they connect using the SSL VPN, they get disconnected and then reconnected. They are saying that the SSL VPN key in the Windows systray is going gray when disconnected and then automatically connects again.
Farrukh Haroon Thu, 08/28/2008 - 08:11
  • Red, 2250 points or more
After how long this happens?
Farrukh
keyyo0200 Thu, 08/28/2008 - 08:15
After a couple of minutes, the time vary. It is happending to all users connecting to the concentrator using the SSL client.
Farrukh Haroon Thu, 08/28/2008 - 08:21
I'm sorry I sound like an investigator now; but does this happen only ONCE and then the VPN becomes stable or it keeps happening?
Does the VPN work BEFORE and AFTER this connection flap?
Farrukh
keyyo0200 Thu, 08/28/2008 - 08:57
No problem. It happens more than once and once it is connected the connection stable.
Farrukh Haroon Thu, 08/28/2008 - 10:48
Can you turn on debugging on the VPNC and post it here?
IKE, IKEDBG
IPSEC,IPSECDBG
All at least on level 9.
Farrukh
