08-28-2008 08:17 AM - edited 07-03-2021 04:23 PM
is there a way to use a DMZ WLC to use the guest access even if the DMZ WLC is not in the same mobility group as the internal WLCs are ? Has there to be a mobility group over all WLCs that this can be handeld ?
Thanks Dennis
08-28-2008 09:17 AM
The DMZ WLC's should be on a different mobility group than the foreign WLC's. Will it work either way.... yes.
Log in to Community
