IPCC Express - Random Failover
Aug 28th, 2008
Hi i have two IPCC 4.0(2)in failover. Weeks ago the servers began to randomly change their roles from active to pasive. I found in the event viewer the event attached.
Also we have a problem with 7941 phones. The agents that has that phones get disconnected randomly.
Any help will be appreciated, thanks for your time.
Jose
Abdulbaseer Mohammed Fri, 08/29/2008 - 22:56
  • Silver, 250 points or more
Looks like some issues in your primary subsystems. You may browse the systems message in appadmin CRS administration or if you can afford re start check for clean sheet if all is good you should be fine.
Good luck.
pepito1983 Mon, 09/01/2008 - 21:23
Hi, can you please give me a hand where to find those system messages. An d how to make a check for clean sheet.
Jose
