VPN 3000 Concentrator
wgranada1
I have a quick question, I have a backup ACS server that was just built now I noticed on my concentrator that under Config => system => Servers = > Authentication I have the primary authentication server in place the question is can I add the backup ACS server as well so if the primary goes away it will automatically use the backup ACS server? Thank you in advance!!!
Premdeep Banga
Level 7
Level 7
Thats the way its supposed to work. Given you have not configured a Group specific authentication server list.
Prem
Please rate if it helps!
Premdeep Banga
Level 7
Level 7
Prem
