Upgrading WAE-612-K9
Answered Question
Aug 28th, 2008
I'm trying to create a new software file in CMS so that I can upgrade my new non-production devices. The problem I'm running into is in the "Software Version" field on the "Creating New Software File" page. I'm trying to use the WAAS-4.0.19.14-K9.bin file that I downloaded from Cisco today. The current version is 4.0.9.b.10.
I've tried putting the new software version in the "Software Version" field, but I keep getting back a message that tells me "Transaction not completed". "Please enter a valid format for the Software Version".
The instructions refer to the following: Specify the version in one of two formats: X.Y.Z-bB or X.Y.Z.b.B
where X=major version,Y=minor version, Z=maintenance version, b=build letter, and B=build number.
Here are the different forms I've tried:
4.0
4.0.
4.0.19
4.0.19.
4.0.19.14
4.0.19.14-
4.0.19.14-K9
4.0.19.14-K9.
4.0.19.14-K9.bin
None work. Can someone point me in the right direction?
Thanks!
Correct Answer by dstolt about 8 years 6 months ago
Clay,
You should use the following...
4.0.19.b.14
Hope that helps,
Dan
Overall Rating: 5 (1 ratings)
Correct Answer
dstolt Thu, 08/28/2008 - 10:27
Clay,
4.0.19.b.14
Hope that helps,
Dan
clayhawks Thu, 08/28/2008 - 13:29
Yep, that did the trick. Some of the time the answer is right in front of your face, you know? Just seemed odd to insert a b in the middle of the filename...
Thanks.
Clay Hawks
