Can't SSH to ASA5550
Aug 28th, 2008
We have two ASA5550's. I copied the configuration from one ASA to another. The configuration on both looks the same. However, I can't SSH to the ASA that I copied the configuration to. I can telnet and Console to it, however. Do you have any suggestions?
Thanks.
Jill
Overall Rating: 5 (1 ratings)
thomasdzubin Thu, 08/28/2008 - 10:51
You probably have to generate the RSA keys with:
config t
ca generate rsa key 1024
since the keys don't get included in the config.
TDz.
jjohnson36 Thu, 08/28/2008 - 16:40
Thomas,
Thanks for your prompt response.
When I typed the above command, it recommended me to use the command "crypto key generate". So, I typed "crypto key generate rsa usage-keys". Do these commands mean the same? I am not sure what key was generated. I was able to SSH, but I want to make sure these two commands are the same.
By the way, I am running version 7.1(2).
Thanks.
Jill
thomasdzubin Fri, 08/29/2008 - 04:50
yes...sorry the commands are the same... I didn't have an ASA in front of me when I replied so I did it from memory.
