Read XML Path
Aug 28th, 2008
I am trying to use the get xml document data step in CRS to read an XML file for the status of a particular call center. What would the path be for the XML data in this XML code?
<OfficeSiteStatus xmlns="http://schemas.datacontract.org/2004/07/Cti.Data.Schema">Open</OfficeSiteStatus>
I should be able to read status "Open" to a variable for later processing.
Normally there is a child node to read but in this case there is no child. How do you read the data from the parent?
