cisco Wireless 4400 password recovery
Aug 28th, 2008
I have configured radius setting on the wireless controller. After applying setting I lost the control. I want to break the password. Pl let me know how I cn be able to break pasword of 4400 wireless controller.
Thanks in Antiscipation.
amitmarathe Fri, 08/29/2008 - 22:57
Thanks for the quick responce. Fortunately I have created a local user priv 15 on wlc. I disconnected WLC from the netwrok. Then I could be able to login through the local user.
I have one question if i dont have fergot the local user id and password, in that case will my configuration will lost during the recovery process?
Thanks for ur help.
Scott Fella Sat, 08/30/2008 - 07:35
That link is for a 4400 router. If you clear the config from the boot, then you will loose all your configuration and will have to configure the wlc fro the startup wizard. Here is a Q&A fro the WiSM, which is the same for the 4400's:
How can I reset the WiSM to factory default settings?
A. Complete these steps to reset the WiSM controller to factory defaults:
1.Enter reset system at the WiSM controller CLI.
2.At the prompt that asks whether you need to save changes to the configuration, enter Y or N. The unit reboots.
3.When you are prompted for a username, enter recover-config to restore the factory default configuration. The Cisco WLAN controller reboots and displays this message:
Welcome to the Cisco WLAN Solution Wizard
Configuration Tool4.The WiSM is now reset to factory defaults. Use the configuration wizard to enter new configuration settings.
dennischolmes Mon, 09/01/2008 - 20:19
How about just going to WCS and adding a new admin level user and then deleting the old?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
