Aug 28th, 2008
Hello, please anybody knows about what's the SAP R3 size packets in order to provide Bandwidth QoS?
Marwan ALshawi Thu, 08/28/2008 - 16:45
the following is config example from cisco press regarding SAP policing maybe helps u:
CAT3550(config)#ip access-list extended SAP
CAT3550(config-ext-nacl)# permit tcp any range 3200 3203 any
CAT3550(config-ext-nacl)# permit tcp any eq 3600 any
CAT3550(config)#class-map SAP
CAT3550(config-cmap)# match access-group name SAP
CAT3550(config)#policy-map UNTRUSTED-SERVER
CAT3550(config-pmap)#class SAP
CAT3550(config-pmap-c)# set ip dscp 25 ! SAP is marked as Mission-Critical
CAT3550(config-pmap-c)# police 15000000 8000 exceed-action policed-dscp-transmit
! Out-of-profile SAP is marked down to Scavenger (CS1)
good luck
if helpful Rate
Joseph W. Doherty Mon, 09/01/2008 - 03:56
Sorry I don't, but R3 isn't real tolerant of delay or drops. Best thing would be guarantee ample bandwidth via QoS (perhaps initially 50% with CBWFQ), monitor actual bandwidth demand of R3 in your environment, then adjust bandwidth guarantee.
