Hirarchial (nested) policy bandwidth reservation
Aug 28th, 2008
My requirement was to run QoS on ethernet sub-interface. To achieve that I have configured the shape (percent) command, in "child" (nested) policy maps, on Cisco 7200.
IOS: c7200-adventerprisek9-mz.124-15.T1.bin
Now after applying the policy on sub-interface, the reserved bandwidth for each class is not being shown accurately in "show" commands:
7206#sh policy-map FastEthernet0/1.1
FastEthernet0/1.1
Service-policy output: ABCCosSub
Class-map: class-default (match-any)
478266 packets, 261182209 bytes
30 second offered rate 12045000 bps, drop rate 0 bps
Match: any
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
100 (%) 0 (ms) 0 (ms)
12157521/12157521 379922 1519688 1519688 125 189961 >>>>>>>>>>>>>>>>>>>>>>>Interface bandwidth is 100Mbps
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 299 477918 261784898 268596 152975206 yes
Service-policy : ABCCos
Class-map: ControlClass (match-any)
8506 packets, 959869 bytes
30 second offered rate 45000 bps, drop rate 0 bps
Match: ip precedence 6
4546 packets, 480554 bytes
30 second rate 23000 bps
Match: mpls experimental topmost 6
3960 packets, 479315 bytes
30 second rate 22000 bps
Queueing
Output Queue: Conversation 265
Bandwidth 20 (%)
Bandwidth 2431 (kbps) >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>reserved bandwidth must be 20% of 100Mbps
(pkts matched/bytes matched) 4116/478504
(depth/total drops/no-buffer drops) 2/0/0
exponential weight: 9
mean queue depth: 3
Attached is the configuration of the router and complete output of "Show policy-map", "Show interface" commands.
rgds/bsn
