08-28-2008 07:03 PM
I have ASA active/standby setup. Seems, when the active fail, it won't preempt to an active state when it becomes available again ... just like HSRP. Is it possible?
thanks,
gerard
08-28-2008 07:33 PM
Gerard, you need to implement preempt command.
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/p.html#wp1885649
Rgds
Jorge
08-28-2008 07:37 PM
I have no option on failover group ...not sure why? I'm using IPSEC plus license.
ASA-Firewall(config)# failover ?
configure mode commands/options:
interface
interface-policy
key
link
mac
polltime
timeout
exec mode commands/options:
active
exec
reload-standby
reset
08-28-2008 08:04 PM
use this link
this one for ACTIVE/ACTIVE failover
but u rae useing active/standby
so use this linke as a config refrence and only configure one group in the example group one
then u gonna be able to use the preempt command
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
good luck
please, if helpful rate
08-29-2008 05:36 AM
I remember now and the reason I have no failover group option. I'm running a single mode.
great help guys and your responses, i will try but no worries this is still in test environment.
08-29-2008 07:49 AM
