2960-24PC-L or 3560-24PS?
Aug 28th, 2008
hi folks,
In a new design I'm deciding wether to go for 2960-24PC-L's or 3560-24PS's as my access layer. I have need for; POE, 24 ports on each switch and to enable either auto-qos or trust cos. No layer 3 is required at the access layer. IP Phones will be used but are NEC DTerms.
Would I be right to assume the 2960-24PC-L will be fine for the job?
thanks
Dave
Mark Yeates Fri, 08/29/2008 - 07:19
  • Gold, 750 points or more
Dave,
The 2960 should work just fine for you. It supports auto QoS and will trust cos markings from your IP phones.
HTH,
Mark
