Object-groups 101 tips?
Aug 28th, 2008
Is it possible that in the CLI to find out in what object-group(s) that a specific IP is located?
I'm currently just dumping the configuration and using wordpad to search it through. It sucks but its the easiest way, for me atlest.
It might be easy with a small configuration but we have alot of object-groups with alot of IP's in each and everyone of them.
Overall Rating: 3 (1 ratings)
azore2007 Fri, 08/29/2008 - 00:28
Hi Andrew
Yea thats what I'm using today.
Just found this, instead of dumping the config,, just type in this in the browser
https://
azore2007 Fri, 08/29/2008 - 01:00
I skip the need to dump the config to a text file and use a wordprocessing program.
Just saves some time.
But no, in the big picture it doesnt help at all
Farrukh Haroon Fri, 08/29/2008 - 09:54
  • Red, 2250 points or more
The best way would be:
"show run object-group | inc |network"
This way you would also see in which object-group that IP is in, but the downside is you will see the names of all other 'network' type object groups as well :)
Farrukh
