Can I change the timezone for CUOM ?
Aug 29th, 2008
we are forced by changing the time the September 1th to decrcease by 1.Now,Our Timezone is GMT+1, but if i change the timezone to GMT will has the same effect as if i decrease the time by 1.
The following is a check that must be done before installation of CUOM :
Critical: Check the time on the machine. If you change the time after CUOM installation you may need to reinstall the OS to get CUOM to work.
Thanks at advance
ivillegas Thu, 09/04/2008 - 13:54
You may change the time zone for CUOM. After changing restart the Daemon Manager to reflect the change.
