samples for redundant trunks on Catalyst 3750 & 3560
Aug 29th, 2008
I've setup a 3750 & 3560 with one "switchport trunk encapsulation dot1q" on port 24 for both Catalyst.
And I'd like to have a redundant trunk to backup this in case of cable or port failure on this.
Hope someone can provide some samples of the Catalyst config for this.
Thanks.
lee.reade Fri, 08/29/2008 - 01:16
  • Silver, 250 points or more
Just config the two ports as an etherchannel, this way if one port goes down you will have second link take over with no downtime.
Guide for configuring etherchannel;
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swethchl.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swethchl.html
LR
