2611 got so many packet error, crc and collision
Aug 29th, 2008
Dear All,
I implemented rate-limit using 2611, but when i see the interface statistic i saw so many packet error, CRC, and Collision. Which cause the network become unstable and so slow, i have to clear ip nat translation, logging, and dhcp binding and even to reload the router first to make it works normal again. But after a while it happened again. All my switches using catalyst 2924. If i use 2611 just for simple routing without rate-limit, no packet error, crc, or collision.
Any idea what was wrong with the router? I used IOS 12.3(5a). Thanks before.
1guanaswitch Sun, 09/07/2008 - 20:04
thanks for replying...
i've set the logging rate-limit... but how do i know what causing the interface have packet error, crc and collision??
is it because the interface on 2611 only 10mbps (ethernet) while the catalyst using 100mbps (fast ethernet) which become bottle neck??
scottmac Sun, 09/07/2008 - 20:35
  • Green, 3000 points or more
It most likely would be a duplex mismatch (one side running half duplex, the other is running full duplex.
Try manually setting both sides.
Good Luck
Scott
