How do I find out the AS number my eBGP neighbour is using to peer with me?
rajib_das Fri, 08/29/2008 - 02:35
Hi lucy,
you can see the AS number of neighbor with "show ip bgp Summary" command
rajib
cisco_lad2004 Fri, 08/29/2008 - 05:15
  • Gold, 750 points or more
in addition to previous reply....u will get error message if u trying configure a differnet AS, I dont recommend it in case cisco removed this safety pin and allows the reconfig on a new AS :-)
TST-POP1-NPE01(config)#router bgp 65001
BGP is already running; AS is 64512
Giuseppe Larosa Fri, 08/29/2008 - 08:51
  • Hall of Fame,
    Founding Member
Hello Lucy,
to see the AS number as seen by others do
sh run | beg router bgp
and look at the line that say
bgp confederation identifier that is the public AS number you are looking for
Hope to help
Giuseppe
