management-acces on Router 3825 via VPN (snmp)
Aug 29th, 2008
I'm using "management-access" command on all PIX I manage to get snmp info from ipsec tunnel (management-access inside) => no problem
Now I'm new with router conf, and I did not find the same command to do that.
So how to access inside interface from VPN... and in my case to get snmp info ?
thanks by advance
Farrukh Haroon Fri, 08/29/2008 - 10:57
By default there is no access-control on the router. You can snmp poll 'ANY' interface from anywhere. Unless you are running some firewall type feature on the router.
