CSS11503 - Won't delete ssl cert file
Aug 29th, 2008
Hi All,
I have 2 css11503's in one armed active/passive mode. I have applied ssl certs on both boxes, one of them gives me the message that key and file are not valid (works fine on primary), I've done a show ssl file and the cert in question is there, when i do a delete ssl file 'xx' it reports the file does not exist so i try to re-import and this fails because 'file already exists'!! Reboot hasn't helped. I have deleted/reimported the rsa key, has anyone else seen this? I am running version, should I upgrade to a better version?
Overall Rating: 5 (1 ratings)
Gilles Dufour Mon, 09/01/2008 - 03:37
it won't be a bad idea to do an upgrade to 8.1(401) has there were many improvements in that area.
In the meantime, you can try to erase the crypto files with the command :
ssl clearfiles
qubenetworks Mon, 09/01/2008 - 03:47
Thanks Giles,
I opened a TAC case and finally got it resolved, I had to import a different file, copy that to the corrupt one (in llama)::
ap_file copy c:/CertStore/ssl/good.pem c:/CertStore/ssl/bad.pem
backout of llama and I could then delete the file using the 'clear ssl file xx.pem' command. The following command::
CSS11501(debug)# ap_file delete c:/CertStore/ssl/
didn't work, as it said you cannot delete Certfiles, I was trying to avoid the ssl clearfiles command (TAC's 3rd option) as there are quite a few on there and I didn't want to reconfigure the whole lot!
Finally have the app session reporting UP and no warnings about ssl configs not the same!
