WS-SVC-CMM Location
Aug 29th, 2008
Hi Is there a correct slot to locate the WS-SVC-CMM module in a C6506-E ?
We have 2 6506-E's in one location with the CMM in Slot 6 and they are running clean with no errors , but on another 6506-E the CMM is in Slot 3 and running up huge errors.
Scott.
Jon Marshall Fri, 08/29/2008 - 03:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Scott
No there should be no restriction other than the obvious with slots for the supervisors. See attached link - Table 1 about 1/3 of the way down which states it can go in any slot.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd8066426f.html
Sounds to me like you may have either a faulty module or slot 3 has a connectivity problem to the switch fabric.
Jon
