08-29-2008 04:08 AM - edited 03-03-2019 11:20 PM
can any one helpout to me?
How to do configure the channalaized E1 on Cisco 7206 and in that multichannel card is there
08-29-2008 11:39 AM
Hello Asi,
if you are using a channelized E3 multichannel E3
you need to go though two levels hierarchy:
define and configure E3 controller
define and configure each child E1 controller
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091d25.html
or if you are using a multichannel E1
Hope to help
Giuseppe
08-30-2008 10:54 AM
Hi Sasi,
To sum it up, you must define the controller for channelized E1/T1 (E1 in your case)
"controller E1 1/0
channel-group 30 timeslots 1-31 "
//where 1 is your row#,0 is your module #
"interface Serial3/1:30"
// So only difference in channalized E1 and serial E1 is that you have to define 30 channel's grouping, rest is same as for the serial"
