Caller ID (CLID) not being passed from SIP to ISDN
mcroft
Hope you can help,
Does anyone know how to ensure that the Callser-ID gets carried from a SIP INVITE message over to a ISDN SETUP message ? From reading cisco papers, it appears that if the "remote-party-id" in the sip-message is populated, then the clid in the isdn-message should be automatically data-filled. But I have tried lots of configurations without any joy.
I am using an AS5350XM with 12.4-6.T3. I see the "remote-party-id" field correctly within the INVITE, but when I debug the ISDN-Q931, I see a blank field. It is not being passed on.
Hope you can help.
Thanks, Matt
INVITE sip:02085125121@11.11.11.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.1:5060;branch=z9hG4bK4718D9
Remote-Party-ID: "MATT" <sip:02074652333@10.0.0.1>;party=calling;screen=yes;privacy=off
Q931: TX -> SETUP pd = 8 callref = 0x0081
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x01C3, N/A
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '02075177151'
Here is the config,
sip-ua
remote-party-id
interface Serial1/6:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn supp-service name calling
dial-peer voice 206 pots
destination-pattern .T
port 1/6:D
forward-digits all
Sascha Monteiro
Level 6
Level 6
On our CUBE (SIP-SIP) we have a line like
From: <>snip@lab-as.sip.softswitch.snip.net>;tag=xx-xx
and we disabled remote-party-id...
