Pix License - UR changed to FO after 3DES/AES upgrade
The Pix525 had FO enabled in A/A mode with an UR license when I bought it. It is not meant for FO setup and I want to use 3DES for VPN. The activation-key process went fine except for saying about Failover being different. After the reboot the box is showing "This platform has a Failover Only-Active/Standby (FO) license". Is this normal? does it mean I have to live without 3DES?
Overall Rating: 3 (2 ratings)
the following is the show ver after the upgrade:
Cisco PIX Security Appliance Software Version 8.0(4)
Device Manager Version 5.2(2)
Compiled on Thu 07-Aug-08 19:42 by builders
System image file is "flash:/pix804.bin"
Config file at boot was "startup-config"
pixfirewall up 11 hours 13 mins
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash E28F400B5T @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 0002.b945.a7db, irq 10
1: Ext: Ethernet1 : address is 0002.b945.a7dc, irq 11
2: Ext: Ethernet2 : address is 00e0.b602.7949, irq 11
3: Ext: Ethernet3 : address is 00e0.b602.7948, irq 10
4: Ext: Ethernet4 : address is 00e0.b602.7947, irq 9
5: Ext: Ethernet5 : address is 00e0.b602.7946, irq 5
<--- More --->
Licensed features for this platform:
Maximum Physical Interfaces : 10
Maximum VLANs : 100
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Failover Only-Active/Standby (FO) license.
Serial Number: 480480115
Running Activation Key: 0xfc134f51 0x2010325f 0xf0c03580 0xb7887034 0x8e33d38a
Configuration last modified by enable_15 at 04:13:23.128 UTC Fri Aug 29 2008
this is the Licensed features for this platform before the upgrade:
Maximum VLANs : 100
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Guards : Enabled
GTP/GPRS : Disabled
This platform has an Unrestricted (UR) license.
Even the Failover changed from Active/Active to Active/Standby. Isnt it weird?
Out of curiosity I tried turn on failover and the screen says it is a standby license and will reload every 24 hours.
cisco24x7 Fri, 08/29/2008 - 10:51
I did run into the exact situation like yours
a couple years ago. When I upgraded the Pix
535 from 6.x to 7.x, the feature goes from UR
to FO. I had to open a Cisco TAC case for this
and it took them a while to figure it out.
I don't know if you notice this but with
version 7.x on the Pix, for some Pix firewalls,
you will see a 4 tuple keys while on other
pix firewalls, you will 5 tuple keys. Very
strange.
