Switching to modules on 6500 chassis
Answered Question
Aug 29th, 2008
In the following display,
Console> (enable) show module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC no ok
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes standby
4 4 48 10/100BaseTX Ethernet WS-X6248-RJ-45 no ok
What would session slot 1 and slot 4 take me to ? The upstream router I believe can be accessed by session slot 2.
To which module should I console in to create VLAN on the 48 port switch.
Rgds.
Correct Answer by Jon Marshall about 8 years 7 months ago
"Meaning, if the 6500 was a native mode type, I would see the prompt
Router>"
Correct (or whatever hostname you have ever given it)
And yes if you are running in native mode you configure both the Layer 2 and Layer 3 from the same prompt.
There is no such thing as a Layer 3 vlan as such, as vlans are really Layer 2. If the switch is running in native mode then you have access to both the supervisor and the MSFC from the same command prompt.
In hybrid mode you have access to the supervisor via CatOS and the MSFC via IOS.
Jon
Overall Rating: 5 (2 ratings)
Jon Marshall Fri, 08/29/2008 - 06:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You are running CatOS on the supervisor and IOS on the MSFC.
To create a vlan
Console(enable) set vlan 10 name client_vlan
To assign ports on your 48 port module into that vlan
Console(enable) set vlan 10 4/21
would assign port 4/21 into vlan 10. You configure all modules from the suprevisor using CatOS execept for the MSFC where you use IOS.
To get to the MSFC from the supervisor
Console>(enable) sess 15
to get back to supervisor just type "exit"
Jon
new_networker Fri, 08/29/2008 - 07:27
Let me get it right Jon. Are the following correct combinations
1) 6500 could provide IOS Supervisor and IOS MSFC
or
2) 6500 could you provide CatOS Supervisor and IOS MSFC.
Secondly, if I were to do session 4 (i.e.
what would it take me to in both supervisor types.
Jon Marshall Fri, 08/29/2008 - 10:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
1) IOS on both is called "native" mode.
2) IOS on MSFC and CatOS on supervisor is called "hybrid" mode.
Not sure i follow when you say would sess 4 take me in to both supervisor types. I have never sessioned to an ethernet module and i'm not sure why you would want to.
Your switch is running in hybrid OR native - it cannot be running both. To configure ethernet ports on a module you do it with either CatOS in hybrid or IOS in native.
Jon
new_networker Fri, 08/29/2008 - 12:06
Router>
And is it here where I can define all the bunch of VLANs for interfacing with FWSM, ACE, IDSM etc and assign switchports to various hosts.
Lastly, can a Layer 3 VLAN be defined on the switch module or it necessarily has to be on the MSFC i.e. SVI.
Thanks.
jonesm111 Fri, 08/29/2008 - 12:45
I believe typically you would do a session 15 to get to the active MSRP from the switch.
jonesm111 Fri, 08/29/2008 - 13:24
Also, you would want to create the vlans on both the switch and MSFC if you want to route the vlans.
I usually create the vlan on the switch first, assign a port to that vlan (you must or L3 vlan on MSFC won't come up), then create the SVI on the MSFC.
Please rate if this helps..
Correct Answer
Jon Marshall Fri, 08/29/2008 - 14:26
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Router>"
Jon
