GK question
Aug 29th, 2008
I have a callmanager and a cme talking via gatekeeper. I am registering my cme with a tech prefic of 3#, and when i dial from callmanager to CME, I am prepending 3#, but the call is still now going to cme, i am not using default technology prefix, any ideas?
I mean my zone and tech prefix are mathing for cme, but the call is still not going to cme???
Overall Rating: 5 (1 ratings)
Marwan ALshawi Fri, 08/29/2008 - 06:25
can u post from the GK config
show gategeeper endpoints
and the GK config
and cme config part that relate to the GK only
try this example:
interface FastEthernet 1/0
ip address
h323-gateway voip interface
h323-gateway voip id CME ipaddr 1719
h323-gateway voip h323-id [email protected]
h323-gateway voip tech-prefix 1#
dial-peer voice 999 voip
destination-pattern .T
session target ras
zone local CME cisco.com
zone local CMM cisco.com
zone prefix CME 3*
zone prefix CMM 4*
gw-type-prefix 1#* default-technology
no shutdown
and restor the techprefix to the default on the CMM 1#*
for CAC u can add for example
bandwidth interzone zone boise [16 for one g729 and 128 for one g711 call and so on]
for troubleshoot use
show gatekeeper zone status
show gatekeeper endpoints
after that u can consider the 3 as the prefix number for CME
NOTE: on CME u need to Enable gateway operation. Enter the gateway command
good luck
please, if helpful ratr
NAVIN PARWAL Fri, 08/29/2008 - 07:21
I do not want to use gw-type-prefix 1#* default-technology on the gatekeeper. so what I did was that I am prepending 1# on ccm when dialing 3... from ccm to cme. but it still does not work.
Marwan ALshawi Fri, 08/29/2008 - 07:33
try this example
interface FastEthernet0/0
h323-gateway voip id zone1 ipaddr 1719
h323-gateway voip tech-prefix 434
dial-peer voice 408 voip
destination-pattern 408
incoming called-number 4345552...
session target ras
zone local zone1 cisco.com
no zone subnet zone1 default enable
zone subnet zone1 enable
no shutdown
if helpful Rate
NAVIN PARWAL Fri, 08/29/2008 - 07:41
what shoud the configuration be on the callmanager side? I promise to rate this post if it helps me solve the problem.
Marwan ALshawi Fri, 08/29/2008 - 22:06
first the important thing to solve ur problem not to get rated :)
now in call manager
Step 1. Define the gatekeeper to CallManager.
The only information that you need for this step is the IP address of the gatekeeper interface. Be sure that the Enable Device checkbox is also selected
Step 2. Set up the actual trunk to the gatekeeper.
If your CallManager is running software version 3.2 or higher, Cisco recommends using H.225 gatekeeper-controlled trunks.
When you are configuring the trunk, you need to give it a unique name to be used to point traffic to the trunk in the next step. You also need to select the gatekeeper that you defined previously from a drop-down box. Add an appropriate technology prefix. You might want a different technology prefix for CallManager, because CallManager 4.0 and higher systems can handle both voice and video traffic. Always set the Terminal Type field to gateway for normal CAC.
Enter the zone name.
It is almost always desirable to have a different zone name for each CallManager cluster that is defined on the gatekeeper. This helps when configuring bandwidth management
in the tech prefix put the prefix the the CME will dial as access code to the CCM
like in the prvous example 403then the phone number
At this point, the trunk should be registered to the gatekeeper and ready for use. You can verify this by using the show gatekeeper endpoints command on the gatekeeper
good luck :)
and hope this helpful
mciarfello Fri, 08/29/2008 - 23:04
Probably the easiest thing to do is route by zone prefix becasue CCME registers to the GK its ephone-dn's as E.164 address. You can verify this with "show gatek end"
If your CCME phones are all 3000 range, then on the gatekeeper put "zone prefix blah 3..." and get rid of the prefixing on the CallManager. You can have more than one zone prefix command in case you also have 4000 range.
CCME to CCM will need a different strategy since CCM doesn't register its DNs with the GK. "gw-type-prefix 123 gw ipaddr {ip_of_ccm} 1720" should be good. The 123 is your tech prefix in the CallManager trunk. Not I didn't put a # for this example. Not required. You will also need a "tech-prefix 123" in your CCME VoIP Dial-peer.
I don't understand your full scenario, but doing the preprending of the tech-prefix just means you have to strip it off somehow on the other end which is extra work.
Marwan ALshawi Sat, 08/30/2008 - 04:45
on the CCM define the gatekeeper
then make a inter-cluster-trunk katekeeper controled
from the gatekeeper information section
chose the ip adress of the defined gatekeeper
on technology prefex put [any number u want to use it as a prefix number]
on the zone put the zone name that u put it on the gatekeeper config
for example
on gatekeeper define one zone
zone local zone1 local.com
no shutdown
for testing use show katekeeper endpoints
for cme
h323-gateway voip h323-id local.com
h323-gateway voip tech-prefix 3
on CCM
create route pattren start with 3 and from the roue pattren route list chose the intercluster-kate keeerper-controled
u created before that point to the gatekeeper
and lets asume u use 3 digits in ur local phones with CCM and u put in the tech-prefix on the CCM in the ICT-GK controled number 4
do the dial-peer on the CME
destination-pattern 4...
incoming called-number 3...
session target ras
this way will work
good luck
Hythim Ali El Hadad Sun, 11/15/2009 - 09:25
I have a question about this phrase that i have a problem like this:
i have also CM-GK-CME
when calling from CMM to CME,the phones show that it is a g729 call and the 'sh gateke ca' shows that it consume 16K
But the problem is when calling from CME to CCM
the phones show that it is g729 call but when 'sh gatekee call' it shows that the call consume 128K,so the gatekeeper need 128 K for this call although I have configured it to use g729,I have configured the outgoing dial-peer on the CME with G729 and the call allready match with,also the DP of the ICT is using only g729
So why the CME insist in using 128 K for this call
Thanks for your feed back
jamesfang98 Fri, 08/29/2008 - 06:29
1. Can you GK see CCM and CME as endpoints?
2. In GK, you don't have default tech-prefix. rght?
3. In GK, did zone prefix include CME DNs?
If you can post GK and GW related configuration, it will helpful for identification
