Problem with analog gateway in CUCM 6.1.2
Aug 29th, 2008
I have a vg224 setup as our analog fax gateway. For some reason the ports that are configured and in use/working show as unknown for both registration and IP address. I have tried resetting the gateway but that has no effect. The lines that are connected are working and can send and receive faxes. What is wrong here?
shabali52 Fri, 08/29/2008 - 06:34
Try restarting RIS Data Collector and Database Layer Monitor on all servers in the cluster, this is non-service impacting.
zzbronski Fri, 08/29/2008 - 07:21
Restarting those services on all servers in the cluster had no efect.
Jaime Valencia Fri, 08/29/2008 - 07:25
  • Cisco Employee,
  • Hall of Fame,
    2011
what are you using? SCCP or MGCP?
if H323 be aware they will never show up as registered
java
if this helps, please rate
zzbronski Fri, 08/29/2008 - 07:30
We are using mgcp. They were showing up as registered yesterday, now today they all show as unknown but are still working.
shabali52 Fri, 08/29/2008 - 07:26
Where does it show not-found? In Publisher or subscriber? or both?
zzbronski Fri, 08/29/2008 - 07:31
I shows unknown on both. But all lines configured in the gateway are still working.
shabali52 Fri, 08/29/2008 - 07:38
this is most likely a synchronization issue and thats why I had recommended to restart RIS and DBL. Not sure if reboot is an option for you at this point, however there are a set of commands you can run to resync the db, I will grab the doc and post it over here.
