acs 4.1
Aug 29th, 2008
Hi Community,
I would like to know if it is possible to run acs 4.1 to authenticate alcatel pabx users.
I authenticate the users on the 2950 cisco switch with acs 4.1 however i don't see in reports of acs 4.1, successful authentication?
can you help me please ?
thanks in advance
Network Engineer
Premdeep Banga Fri, 08/29/2008 - 07:14
to see successful login on a new installation you need to turn on Passed Authentication Reports from,
System Configuration > Logging >.... CSV Passed Authenticaiton.... > Check it to turn on.
IF alcatel pabx supports Radius and/or Tacacs, ACS will authenticate the users on that box.
Please rate if it helps!
joseph-mayo-botele Mon, 09/01/2008 - 07:31
Thanks for your reply, he helped me to resolve this issue.
I have another issue : In the reports, i don't see incrementation of AAA Client in Logged-In Users, must i configure one thing in acs to view users logged inside the system ?
Thank you for your response.
Premdeep Banga Mon, 09/01/2008 - 07:35
Your network devices must be configured to send accounting information to the ACS server.
You router/switch should be configured with commands like,
aaa accounting exec default start-stop group ....
joseph-mayo-botele Mon, 09/01/2008 - 22:20
I want to know if it is possible to authenticate MICROSOFT WINDOWS SERVER through ACS.
can you tell me the headlines to perform this task please ?
Thanks for your help
