UCM 6.0.1 Device Pool Missing MoH Fields
Answered Question
Aug 29th, 2008
I do not see the "User Hold MOH Audio Source" or "Network Hold MOH Audio Source" fields when configuring a Device Pool. Were these fields removed in UCM 6.0? Thanks, Tim
Correct Answer by Jaime Valencia about 8 years 9 months ago
they're under the common profile now
java
if this helps, please rate
Overall Rating: 4.5 (2 ratings)
Correct Answer
Jaime Valencia Fri, 08/29/2008 - 07:18
  • Cisco Employee,
  • Hall of Fame,
    2011
java
tim_roper2 Fri, 08/29/2008 - 07:45
Thanks, I found it under Device --> Device Settings --> Common Device Configuration
