call pickup quest
Answered Question
Aug 29th, 2008
Hi all,
I got several lines and its possible to call all of them over line group and hunt pilot (one defined number - you call and all phones in group are ringing). And there is problem, I cannot adjust this hunt pilot number to the call picku group. So if somebody call on line within group, its possible to pickup call, but if somebody calls on this number which broadcast to all phones its impossible to pick call up. Im picking from number which is of course outside of this "broadcasted" group. Its on CCM 4.2. Pls dont you know some solutions how to arrange it?
Correct Answer by Rob Huffman about 8 years 7 months ago
Hi Thomas,
This can be fixed, you are hitting this bug CSCsb12946 which prevents this feature from working ;
Here is the fix :)
Set enterprise parameter (System->Enterprise Parameters->Cisco Support Use 1) Cisco Support Use 1 to CSCsb42763 (case sensitive)
This operation added listbox (Route Plan->Route/Hunt->Hunt Pilot->hunt pilot XXXX -> Call Pickup Group) Call Pickup Group.
From this doc;
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11612191
1.- Enter
CSCsb42763 (in mixed case) in the Enterprise Parameter 'Cisco Support
Use 1' under the new group 'Cisco Support use Only' and click update. Only the value
CSCsb42763 in this parameter can enable the configuration. Change the
value to anything else to disable this functionality.
2. Go to Hunt Pilot Configuration page and select a call pickup group from the Call
Pickup Group dropdown list and click update.
CSCsb42763
Call Pickup fails on Hunt List
Issue:
Call pickup fails for hunt list when call is CFA from Route Point in 4.1(2)ES41. This is not the designed functionality for this issue and will break the Call Pickup logic.
Workaround:
Use multiple shared lines & CFNA between each shared line.
Related Bugs
Call Pickup fails when ringing line list member
Symptom: Selecting PickUp or GPickUp does not pickup the call from any of the members of a line group. Condition: CM 4.x Workaround: None. Feature not supported. Further Problem Description: Defect CSCsa66224 may appear to have allowed this feature to work in earlier versions.
Call Pickup from line group member fails after es installed
Symptom: A call is CFNA to a hunt pilot/line group. The call can no longer be picked up. Conditions: Calls CFNA to a hunt pilot. 4.1(2)ES36. Workaround: None
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 08/29/2008 - 07:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Thomas,
Here is the fix :)
From this doc;
1.- Enter
CSCsb42763
Issue:
Workaround:
Related Bugs
Hope this helps!
Rob
tprochazka Fri, 08/29/2008 - 08:14
Perfect, it works. Thanks very much. Im normally networker and IP telephony drives me crazy :-)
Jaime Valencia Fri, 08/29/2008 - 07:44
  • Cisco Employee,
  • Hall of Fame,
    2011
in theory there is nothing to fix as it's working as designed but since many people thought it was "broke" there is a bug to enable this
IP Telephony: interesting problem with hunt groups and call pick up groups
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc1adbf
Please try searching previous posts as this was just asked 2 days ago
EDIT: Rob you just beat my morning-3hoursleep typing skills =)
java
if this helps, please rate
Rob Huffman Fri, 08/29/2008 - 09:01
  • Hall of Fame,
    Founding Member
Hi Thomas,
You are most welcome! Don't worry, this stuff drives us all crazy at times ;-)
Jaime, 3 hours sleep?? Were you out doing the "Cisco Disco" last evening? Just kidding, you always Rock no matter how much sleep you've had.
Take care,
Rob
Jaime Valencia Fri, 08/29/2008 - 09:14
  • Cisco Employee,
  • Hall of Fame,
    2011
haha, something like that. i listen to a radio show from 11 PM to 1 AM on Thursdays but sometimes they do the extended version (since no one complaints =) ) and keep on going, so it ended at 2 AM - 2:30 and i got shift at 6 AM so i only got 3 hours sleep.
i need a triple espresso to keep on going for the rest of the day jeje
take care Rob
java
