Headset for 7921?
yankeestom
The headset jack appears to fit 2.5mm headsets, but I can't get any to work. You can hear but not be heard. Is there a specific adapter or headset model that I need?
testeven
Hi!
We have tested quite a few accessory headsets for the 7921s. The compatibles are the (2.5 mm, 3 band - 4 conductor) models from Plantronics and Jabra.
www.plantronics.com
www.jabra.com
Cisco Unified Wireless IP Phone 7921G data sheet
http://www.cisco.com/en/US/partner/products/hw/phones/ps379/products_dat
a_sheet0900aecd805e315d.html
Hope this helps! :)
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
testeven
Hi!
www.plantronics.com
www.jabra.com
Hope this helps! :)
Tere.
Thanks! I had only tried the 2 band connectors.
