Denied ICMP type=3, code=3
Aug 29th, 2008
I've set the inside 172.17.193.x/24 cisco catalyst switches to sync with an outside time server 66.96.30.91.
I'm getting the following
Built inbound ICMP connection for faddr 66.96.30.91/0 gaddr x.x.x.x/0 laddr 172.17.193.52/123
Teardown ICMP connection for faddr 66.96.30.91/0 gaddr x.x.x.x/0 laddr 172.17.193.52/123
Built inbound ICMP connection for faddr 66.96.30.91/0 gaddr x.x.x.x/0 laddr 172.17.193.53/123
Teardown ICMP connection for faddr 66.96.30.91/0 gaddr x.x.x.x/0 laddr 172.17.193.53/123
Denied ICMP type=3, code=3 from 66.96.30.91 on interface outside
Any ideas why???
Here is the config of my ASA:
ciscoasa# sh run
: Saved
ASA Version 8.0(4)
hostname ciscoasa
enable password xxx
passwd xxxx
names
interface Ethernet0/0
speed 100
duplex full
nameif outside
security-level 0
ip address outsideip 255.255.255.240
interface Ethernet0/1
speed 100
duplex full
nameif inside
security-level 100
ip address 172.17.193.100 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot config disk0:/exit
ftp mode passive
clock timezone mst -7
clock summer-time mdt recurring
access-list split_tunnel_list standard permit 172.17.193.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.17.193.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list inbound_on_outside extended permit icmp any any
access-list inbound_on_outside extended permit tcp any host outsideip eq 5555
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnuserspool 192.168.10.101-192.168.10.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.17.193.0 255.255.255.0
static (inside,outside) tcp outsideip 5555 172.17.193.96 5555 netmask 255.255.255.255
access-group inbound_on_outside in interface outside
route outside 0.0.0.0 0.0.0.0 gw 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
support.edm Fri, 08/29/2008 - 11:03
http server enable
http 192.168.10.0 255.255.255.0 inside
http 172.17.193.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set firstset esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dyn1 1 set transform-set firstset
crypto dynamic-map dyn1 1 set security-association lifetime seconds 28800
crypto dynamic-map dyn1 1 set security-association lifetime kilobytes 4608000
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
crypto isakmp nat-traversal 3600
telnet timeout 5
ssh 172.17.193.0 255.255.255.0 inside
ssh 192.168.10.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
management-access inside
dhcpd address 172.17.193.101-172.17.193.254 inside
dhcpd dns 172.17.193.6 interface inside
dhcpd enable inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 66.96.30.91 source outside
group-policy vpnuserspolicy internal
group-policy vpnuserspolicy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list
address-pools value vpnuserspool
username admin password xxx encrypted privilege 15
username admin attributes
vpn-group-policy vpnuserspolicy
tunnel-group vpnusersgroup type remote-access
tunnel-group vpnusersgroup general-attributes
default-group-policy vpnuserspolicy
tunnel-group vpnusersgroup ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa#
robertson.michael Fri, 08/29/2008 - 11:12
  • Silver, 250 points or more
Try enabling ICMP inspection with the following commands:
inspect icmp
Hope that helps.
-Mike
support.edm Fri, 09/05/2008 - 08:41
I did that...still the same error. The ASA and the switches are not syncing properly with the external time source.
Any ideas?
g.meerkoetter Fri, 09/05/2008 - 10:55
Hmm, if the remote host 66.96.30.91 sends icmp type 3 code 3 (aka port unreachable), then there
is no server running on port 123/udp (or maybe it's explicitely configured to pretend that it is not running).
I get the same answer here, therefore I'd suggest you try with a server that is known to be working.
