Need help on bridging
sateeshk10
hi,
In my network i have some switches which is runing Bridigeing instance.. now i am planning to migrate to STP. what precaution in need to take..
connectivity..
COre-- BRIDGE SW(2948) -- PC
sample config of one VLAN in both the switches..
interface BVI64
ip address 172.16.164.3 255.255.255.0
no ip redirects
no ip directed-broadcast
standby 164 priority 100
standby 164 ip 172.16.64.1
interface Vlan164
ip address 172.16.64.2 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
standby 164 ip 172.16.164.1
standby 164 priority 200
standby 164 preempt
For two they have given two GW for one VLAN..
pls help me out
sateesh kumar.k
Hello Sateesh,
everything is ok
be aware that this switch could be unable to support L3 Vlan this depends on the IOS code on it.
You may need to upgrade it to use the Vlan Syntax and to take advantage of real PVST+.
Hope to help
Giuseppe
9 Replies 9
Giuseppe Larosa
Hello Sateesh,
BVI are used by IRB = Integrated Routing and Brdiging
you can equate one BVI as one L3 Vlan like Vlan164.
all ports with bridge-group 64 are part of the same L2 VLan broadcast domain
be aware that STP is already running on IRB may be with a standard 802.1D CST version
if you do show spanning-tree on the switches using the BVI you can see it
Hope to help
Giuseppe
pls find below sh span-tree from BVI..pls chk an d confirm
if so what to do...???
sw#sh spanning-tree
Bridge group 132 is executing the IEEE compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address 0003.9f17.a807
Configured hello time 2, max age 20, forward delay 15
Current root has priority 8192, address 0009.b7ad.e083
Root port is 63 (GigabitEthernet50.132), cost of root path is 4
Topology change flag not set, detected flag not set
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0
bridge aging time 300
Port 4 (FastEthernet1) of Bridge group 132 is down
Port path cost 19, Port priority 128
Designated root has priority 8192, address 0009.b7ad.e083
Designated bridge has priority 32768, address 0003.9f17.a807
Designated port is 4, path cost 4
Timers: message age 0, forward delay 0, hold 0
BPDU: sent 0, received 0
Hello Sateesk,
just check that the root bridge ID is that of your core switch
on interfaces the core switch should revert to IEEE 802.1D instead of using PVST+.
If the core switch is the root bridge and is using 802.1D on the port to the switch using BVIs everything should be fine
Hope to help
Giuseppe
pls find below the my core sw spantree..bUT MAC ADD DIFFRENT..PLS CHK
COreSW#sh spanning-tree
VLAN1 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 8192, address 0009.b7ad.e000
We are the root of the spanning tree
thanks
sateesh
Hello Sateesh,
0009.b7ad.e000
vlan 132 without MAC address reduction means a different mac address for each vlan instance.
do a show spanning-tree vlan x on core switch
where x is the vlan that pairs with Bridge-group 132
It should be fine a good news is: "ieee compatible Spanning Tree protocol"
Hope to help
Giuseppe
Hi ,
your are right..pls find below the same..
pls let me know shall i enable STP on my sw
crsw#sh spanning-tree vlan 132
VLAN132 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 8192, address 0009.b7ad.e083
sateesh
And also my plan that...i will take out this sw from network and reconfigure for STP and i put back into the network...
is it ok..
sateesh kumar.k
Hello Sateesh,
everything is ok
Hope to help
Giuseppe
Thanks for your excelent help..
sateesh kumar.k
