CUPC not seeing Calander
Aug 29th, 2008
New installation question
Customer has cupc clients and things seem to be working but there is an issue in that it is not correctly showing a user's status if their outlook calander indicates that they are in a meeting.
They have set in their preferences that this should be the case and in the show status, all the indicator are green.
Any thoughts?
DOUG DAVIDSON Tue, 09/02/2008 - 12:47
What does the troubleshooter say on CUPS? Is everything green there?
Are they running Exchange on one server and OWA on another server? I found out from TAC that it will not work if you are running in a "clustering" environment. I do not consider OWA and Exchange on different boxes clustering.
Waiting to see if it is resolved in CUPS 7.0.
HTH,
Doug
mhansen@peakips... Fri, 09/05/2008 - 13:02
I also have never seen this "feature" work. i am waiting for 7.0 before i really dig into it.
Jonathan Schulenberg Fri, 09/05/2008 - 18:55
  • Cisco Designated VIP,
    2017 IP Telephony
At least in CUPS 6, I believe there is a limitation where CUPS can only check Exchange calendars on a single Exchange server. If the customer has multiple Exchange servers in their environment, it will only see calendar data for mailboxes residing on the server it is connected to.
